Option "close the results dialog after sync" not appears
thagordezueira
Hello
Sorry for my bad english.
I'm using RTS to sync two folders, but every time RTS syncs, the results screen appears.
I found in the following link that the option close results should be enabled but this option does not exist in FFS
https://freefilesync.org/manual.php?topic=command-line
These are the available options
Show Summary
Sair (logout)
Sleep
Desligar (Shutdown)
Can someone help me?
Thank you in advance.
Gianni1962
You must save your configuration as a batch job.
User Manual - Schedule a Batch Job
Take a look at Batch Jobs in the Video Tutorials section of the site.
Video Tutorials
Also take a look at Tips and Tricks in the Manual and in the Video Tutorials section.
User Manual - Tips and Tricks
Gianni1962
@Zenju
In FFS 9.5 is missing the "Close progress dialog" option available in previous versions!
EDIT:
The Exit option correspond to the old "Close progress dialog" option.
It does not mean "Logout".
@Gianni1962:
The design between 9.4 and 9.5 has changed as follows:
9.4: "on completion" is executed after sync, but not if cancelled by user or error handling was set to "Stop".
The latter wasn't correct, consider you've set up a command line to shut down the PC, but when an error occurs the shut down is not happening.
9.5: "on completion" is now always executed except if cancelled by the user. Additonally conditions like "on errors" and "on success" are available. The "on completion" box was removed from the batch config dialog and now is only available from the sync config dialog.
9.4: "on completion" presented standard commands to shutdown/sleep/close progress dialog
This was problematic if you were primarily using a ffs_batch config, but then wanted to change a few settings and test your config via GUI: As a result, the computer shuts down unexpectedly, or closes the progress dialog which is also annoying.
9.5: The "shutdown/sleep" commands are moved from the old "on completion" to "When finished", a configuration option that is only available via the batch config dialog or can be dynamically set by the user during sync. The old "Close progress dialog" option was moved to "When finished: Exit". Thus it's now possible to exit FFS even in GUI mode, but it's not possible anymore to only close the progress dialog in GUI mode (which was mostly useless anyway).
Addtionally one can now "Run minimized" but "Show summary" when finished, which was not possible before.
9.5: The "Ignore errors" checkbox is now shared between GUI/Batch which solves viewtopic.php?t=4661&p=15600&#p15600
D363
I wish I had known about this before updating. I have no use for a summary screen and have always set FFS to close it automatically. 9.5 isn't going to work for what I need to do. Where can I get a copy of the 9.4 installer?
Gianni1962
The Exit option is not ok?
D363
No. I need the app to remain open.
Gianni1962
You can download old FFS versions from Filehippo.com
FreeFileSync for Windows 9.4
but it is not the very latest 9.4 version.
I keep older versions of any software so I have uploaded to WeTransfer the very latest 9,4 for you:
FreeFileSync_9.4_Windows_Setup.zip
D363
Thanks, it is also my practice to keep old versions. This is one of the few times I didn't and I've been kicking myself.
ETA: By way of explanation, since the helpful folks at Android decided to hobble our devices with MTP I have relied on FFS to keep my phone and various other Android devices in synch. Unfortunately, the extremely unreliable nature of MTP means that many attempts fail and setting FFS 9.4 to close the progress dialog lets it automatically display any files that weren't updated. With FFS 9.5 I would have to re-open and do a full scan which, again due to the horrifically poor performance of MTP, can take several minutes. None of this is a failure on the part of FFS, in fact I find the new features very useful it's just that they don't work in my particular case.
Impossible not to mention the classic here :D
Gianni1962
@D363
What about the "Show summary" option?
@Zenju
LOL
D363
@D363
@Zenju
LOL Gianni1962, 10 Nov 2017, 15:52
@Gianni1962
Summary shows something went wrong but doesn't specify which files are involved.
@Zenju
One of my favorites!
