I noticed that the only thing I can do to a saved session is "remove entry from list".
I want to rename a session entry. How can I do that?
Shai
rename saved session
Rename the corresponding file on disk, whether it is a .ffs_batch or a .ffs_gui file.
Then Open it from FFS and Remove the old name from the list.
Thank you for that! I guess I wasn't expecting such a long procedure just to rename a session. I opened a feature request to maybe make this easier in the future
