In continuation to the renaming procedure given here: viewtopic.php?t=4802
I feel this should be a very simple ability yet it seems that to rename a saved session entry one needs to do too much:
- close FFS
- locate the directory where the saved session is (the .ffs_gui or ffs_batch file)
- rename the file directly on the disk
- open FFS
- open the saved .ffs_gui or ffs_batch file from within FFS
- "Remove entry from list" in the configuration panel
I suggest to just allow a rename/edit or a saved session entry right from the configuration panel (right-click with the mouse, or a button to allow rename/edit.
feature request: rename session entries from within the app
Done. A new context menu option to rename configurations has been added:
https://www.mediafire.com/file/77a4apx2nau1lq1/FreeFileSync_10.13_%5BBeta%5D_Windows_Setup.exe
Brilliant!! Thank you!
