Minimize on Mac makes application disappear!
minienigma
Kind of a weird issue -- using the Version 9.7 donation edition on Mac OS X 10.10.5. While synchronizing files, clicking on the down arrow makes application window, and indeed the application itself disappear -- as if someone had selected "Hide Application" or quit instead.
However, the application itself appears to still be running in the background. I can see it using Activity Monitor -- there are two "FreeFileSync" processes running, synchronizing files in the background. But no matter what I do (short of killing the background task and restarting), I cannot get the application to reappear. The application icon for the instance that's running hidden does not appear in the Dock. Likewise, the Application does not show up when using the Command-Tab key combo. It does not show up even in "Force Quit Application" window using Command-Option-ESC key combo.
Not sure if the application will behave the same if the standard minimize (yellow) button is selected instead.
The blue down button minimizes into the notification area.
gdcutting
Respectfully, the response to the original question is useless. The user already stated that pressing the down arrow button minimized the window. Zenju restates this (removing any reference to the problem that the window can't be recovered) and makes no attempt to provide a solution.
I have encountered this issue myself on Mac OS. Pressing the minimize button makes the window go away but it does not appear to me recoverable (at least not in any obvious way). There is nothing FFS-related in the notification area, as the button description suggests should be the case after minimizing. I went into Activity Monitor, which confirmed that there is still an FFS process running and taking up CPU cycles. But there is no way through Activity Monitor to restore the window. FFS also does not appear in the Dock (the usual way of restoring windows). I also tried using ctrl-down while in the FFS app (which normally allows the user to switch between application windows) but this didn't work either. FFS is unusual in a Mac context in that the user can create multiple instances of the same application (rather than multiple windows within a single running instance), which I believe is a holdover from the Linux scheme of things.
This is definitely a bug and after five years one would expect a response or solution. I have a large (1.3TB) sync in progress, and I do not want to force the FFS process to quit because I am worried about file and disc corruption. For an application which often is allowed full disc access and manages large numbers of files, not being able to access the window (and thus having no orderly way to terminate the sync or the app itself) is a serious issue. An updated response, one with some information this time, would be appreciated. Thanks.
keithnicholls
Hello all. I'm sure this has been listed somewhere on this forum, but I couldn't find it, so forgive me if everyone knows this now. When you minimize the Status window of the FreeFileSync application on a mac, it "minimizes" to the top Mac Menu Bar with an icon that will bring up that session.
s_decoster
I didn't see this in the top Menu Bar. I also clicked on the arrow down to minimize but can't seem to get the window back. The sync should take 2 hours to finish so my only option is to wait and hope it gets done. I closed the FFS app on the mac, but it seems that the syncing still goes on. So this seems indeed a bug.
Yeppers
I've also encountered this issue. It seems like this feature is designed to minimize FreeFileSync to Windows taskbar, but wasn't modified in the macOS build to work with a functional equivalent, like minimizing to the dock or to a menu bar icon. It would be helpful if there was at least a Terminal command to restore the minimized window so there was a way to interact with it short of killing FFS entirely, or waiting for however long for the running job to compete.
arcaneemergence
I also encountered this issue now on version 14.9. The instance gets hidden. However, there is no item in the menu bar (which is what 'minimize to notification area' sounds like it would be doing), also there is no element in Mission Control and FFS doesn't appear in Dock anymore. I can start FFS, but it opens a new completely uncoupled instance, as if I would have re-installed it, with no settings from before taken over and no configuration available, Gdrive account also needs to be reauthenticated.
The sync is still running in the background (Activity Monitor still shows an instance with CPU and IO), and either after the sync is finished or if the process is killed, it's possible to go back to FFS with all my configs and authentications again. So, it seems like it disappeared during the sync time into an unfindable state.
I would appreciate any help or future fix. Thank you for your great piece of software!
