In SynchronizeIt!, you could define variables, e.g.
Path: F:\Exchange\Upstairs
Then you could simply refer to this variables:
$(Stick1)\MyPictures
For my usage pattern, this was extremely handy. Do you think you could implement something similar?
Thanks very much for considering this and best regards
Pesche
edit: this is similar to Brians 2nd feature suggestion:
2. I like the feature of being able to change the drive name from D: or E: to the disk name like "USB_DRIVE_1" in case the drive letter changes. Besides the drop downs or editing the .xml, is there a GUI way to change all the folders to the drive name all at once? I would envision an "Apply to all" silverturbo, 02 Jan 2018, 20:14
