Copy only new file to different folder
I like to know if it's possible to copy the files to a folder with timestamp but only the modified files, this is for send later only the modified files to a client.
Sure, this can be set up with custom sync rules in the sync config dialog.
Can you guide me with this because i didn't find anything in the help about custom rules
I can try to help you if you can be more specific about what you want to do. (Are you trying to name the folder with a timestamp in the name?).I like to know if it's possible to copy the files to a folder with timestamp but only the modified files, this is for send later only the modified files to a client.lindel
I have a folder with sripts and like to move to a different folder only the new or modified script to then copy to another pc to be executed.I can try to help you if you can be more specific about what you want to do. (Are you trying to name the folder with a timestamp in the name?).azfuller
I also need help on ths.
I need to copy the modified files (only those) to a separate directory. Reason for this: due to harddisk error or virus, some of these files have been modified to size 0. I don't want them to replace the previous set of files, I rather want all modified fiels elsewhere. (another directory tree).
With versioning, I can do something similiar but not quite:
I get the old versions of the modified files in a separate directory, and have the new versions in my original backup target.
But I want the new versions in the separate directory and the old versions in the target untouched. is that possible? If yes, I didn't understand how to do.
You can do this since FFS 7.3: "New context menu option to copy selected files to alternate folder (create diffs)"I also need help on ths.
But I want the new versions in the separate directory and the old versions in the target untouched. is that possible? If yes, I didn't understand how to do.optokl
thanks for the info.
I have 7.4 but: .. where is that context menu? On rightclick?
I tried all obvious elements (left dir tree, left files, right files, all icons in settings dialog for versioning, but am blind and can't find anything.
thanks,
Klaus
thanks,
Klaus
Right-click on selected files from the main dialog:thanks for the info.
thanks,
Klausoptokl
https://freefilesync.org/manual.php?topic=tips-and-tricks#copy-to-alternate-folder
thanks - that did it. I was so intend on finding a 'diff' that I didn't see the 'copy'.
