version 9.8 slower than 4.6
tronuy
Hi.
i upgraded our version(4.6) to 9.8 and remarked a problem with copmare speed
25k small files(2kb), by content
version 9.8: 1:20 min and then compare 0:32 min
version 4.6: 1:09 min and then compare 0:23 min
Maybe anybody can help me, and say, why new version work slower
Also, i tried find older version on site, but i see 5.0 and then 9.6, where another versions?
Gianni1962
You can find old FFS Windows versions here https://freefilesync.org/archive.php and here https://filehippo.com/en/download_freefilesync_windows/history/
I can't help for your speed question.
tronuy
thank you for second link, but where i can find link created by author? I need a trusted source.
At this site absent intermediate versions between 5.0 and 9.6 for Windows.
Gianni1962
Many links are missing but probably the files are there.
https://freefilesync.org/download/FreeFileSync_4.6_Windows_Setup.exe
Copy the link above, paste it in the browser address bar, change the version numbers and with a little luck you will be downloading the desired version from the author site.
tronuy
version 4.6 is not between 5.0 and 9.6 =) i saw this link
ffs began slower working by version 7.0 and 8.4,
Gianni1962
Zenju few months ago had given an explanation for the missing files, something to do with the hosting server, now I can't recall exactly.
However, in my experience you can trust https://filehippo.com.
tronuy
thank you.
If it possible, can Zenju comment my problem with speed?
This is really a problem with the latest versions or is it a feature of new versions and can not be recovered
