New Layout
Illioc
Hi, I'm using FFS for years and I've nothing to suggest about its behaviour as it's absolutely fine for me.
But I'm still proposing to consider changing the general layout of the screen.
My reason to suggest this is that I'm using FFS on a laptop with small resolution.
So here we are:
- At the moment, the item name/relative or full path can be set on the 2 panels.
- In my case, I like to see the full path, plus size, plus date.
- As a result, it's too large for my screen.
My suggestion is:
- To transform the 2 panels in 3 panels:
1 = Item (With or without full or relative path)
2 = Size and date on the Left
3 = Size and date on the Right
- As a result, the width of the 3 panels should be less than the current 2 panels
Another option:
- To automatically open and select on the tree panel (Overview) the selected folder.
- (At the moment, selecting a folder in Overview highlight the files in the 2 "files" panels, but not the reverse)
- If selecting a file on the Left / Right panel could open and select its folder in the Overview, then I could just show "Item name" in the files panels and solve my width issue.
Both option would be fine, and I don't know which one is the most difficult to implement.
