Deleted files location by Freefilesync
shoaib12
Dear Experts,
I have a big trouble by just a small click,
I want to synch my two external drives to be synch but unfortunatley i have selected data drive destination drive and empty drive as source drive. And then software deleted my 250GB data and then i realise my mistake.
I have selected the option that deleted files should my move to recycle bin but now i didnt found any thing in my recycke bin. I also tried to recover my data by my file recovering software but it found not my actual data. So kindly help me to how to find this data. I am also attachind the option selected in the software.
Hope you will help me.[](C:\Users\Shoaib\Desktop\file%20sync.png)
shoaib12
Any solution Plzzzz????
reynaldocuiaba
Got the very same problem. Lost 7000 photos!!! Already used several softwares (such as "Stellar Phoenix") and didn't found the data. Please, if u find a solution, let me know!
The best you can do is use an undeleter tool, depending on the deletion settings:
https://freefilesync.org/faq.php#restore-files
reynaldocuiaba
I've tried several undeleter tools, there is no signal of the the deleted files. Any sugestion about an especific tool?
I've tried several undeleter tools, there is no signal of the the deleted files. Any sugestion about an especific tool?reynaldocuiaba
I can't make any promises for your case, but that last time I had to restore deleted files the only tool that worked was GetDataBack, while none of the popular free tools found any data.
petrovski80
The ony free tool that I have good experience with is Testdisk + PhotoRec from CGsecurity.
