I'm a huge fan of the software, been using it since around the version 9.1 days.
I'm currently running a comparison by file contents (after 3 years of comparing by file time/size only) and have my hard disks running along at 50MB/s. However when I need to do another HDD intensive task (like working with compressed files) it runs slower because the HDD has to do two things at once.
I would therefore like to request the addition of a "pause/resume" button during the comparison process, so we can temporarily suspend the comparison to briefly free the hard disk while we do other tasks.
If that's not possible, perhaps a way for FFS to save checkpoints/progress of comparison up to that point so it can be restarted where it left off?
[Feature Request] - Pause button during comparison
+1 to save the comparison.
Thank you for "FreeFileSync" very good software.
Feature request: Save comparison to close and continue later
Will such PAUSE button be ever implemented?
When I run my Synchronization process I cannot play music and video for an hour as the process drains my computing resources [viewtopic.php?t=10431&hilit=5+minutes#p39382] - hence I am unable to even check a quality of some file, which is plain disrupting to my workflow thus annoying
And this
And this
would also come in handy, because users could e.g. reset the system when something outside FPS goes wrong[...]
Feature request: Save comparison to close and continue later WilliAmaya, 06 Jun 2023, 03:19
And literally just a button - as it is already possible to pause Synchronization:Will such PAUSE button be ever implemented?
[...] Synchronizator, 10 Jul 2023, 09:46
viewtopic.php?t=10479
If that's not possible, perhaps a way for FFS to save checkpoints/progress of comparison up to that point so it can be restarted where it left off? LMF5000, 30 Mar 2018, 09:59
+1 For this feature!
