An earlier version of FFS allowed the user to ignore errors before syncing files. However I can't find this feature on the latest version. This is a problem because half way through the sync FFS stops on a protected file and user intervention is required to proceed causing delays. Is there any way to set FFS to ignore errors before syncing files? Your thoughts would be appreciated.
Kind regards
Chris
How To set FFS To Ignore Errors Before Syncronising
The option is still there: https://freefilesync.org/manual.php?topic=synchronization-settings
Thank you very much. Now I found it.
Kind regards
Chris
Kind regards
Chris
