Hi!
I had a donation edition of FreeFileSync, but when I tried to update to version 10 the update failed and I lost everything.
I've now downloaded the plain version of 10, but I would like the donation edition back
Failed Update
I've followed the update link from 9.8 - it downloaded 10.1, *said* it had installed it, but when I started FFS it was still 9.8 - I've even tried to install to a different path, again it claims to have completed the installation, but the new folder is not created and nothing is updated.
Sounds like a job for Process Monitor: https://freefilesync.org/faq.php#tracebut the new folder is not created and nothing is updated. chickpea, 04 Jun 2018, 13:45
What does this even mean? => Process Monitorupdate failed and I lost everything. BristolPete, 03 Jun 2018, 20:00
So just install it again, no? (You should have backed up your installer, but even if not you still have the confirmation email with the download link)I've now downloaded the plain version of 10, but I would like the donation edition back BristolPete, 03 Jun 2018, 20:00
I've rebooted, and I've managed to install 10.1 in the original folder. I then made a donation and downloaded the new file, but that has the same problem; doesn't install, though it says it has.Sounds like a job for Process Monitor: https://freefilesync.org/faq.php#trace Zenju, 04 Jun 2018, 21:37but the new folder is not created and nothing is updated. chickpea, 04 Jun 2018, 13:45
Is it actually a different .exe, or can I just copy the key file to the start folder?
If I can't get the donation edition, that will be my last donation. I've donated several times before, never had an issue like this.
Again, follow the link above and install while Process Monitor is running. Then we'll see what we've got.
