I would like to identify updated files from Folder A to Folder B but instead of updating Folder B I would like the updates to go into a Folder C. Would this be possible with FreeFileSync?
Thanks,
Louise
Can update create new folder?
@Louise:
Check out the use of Ctrl-T.
See here in the section "Copy files selected on the main dialog to an alternate folder and thereby save a "diff":"
