Leaves empty folders
LarsErikOsterud
I had some folders containing norwegian characters.
They caused problems for some of my MP3 players.
So I change the names. And synced my SD and USB cards.
New folder was created. Files in old folder deleted. Files in new folder added.
BUT. The old folder - now empty - was not deleted (even when not existing in the source).
I thought using "mirror" should create a mirror. Removing all not on the "source" side.
Are you able to reproduce and have some more information?
LarsErikOsterud
Happended with all the folders I renamed.
Files inside where deleted but not the folder.
No problem deleting the folder from Windows Explorer.
Screenshots, error messages, log entries?
Honasss
It seems I have same problem. Empty folders on the target side cannot be deleted, folders are really empty.
I have tried filter:
or
LarsErikOsterud
I found something.
On the one "configuration" that leaves empty folders the to and from are: "D:\Musikk\" and "F:\Music\".
On the ones that have no trouble (tested one now and verified that folders was on delete list) it is: "D:\Musikk" and "F:\Music".
Could the trailing "\" in the source and target mess with folders on next level like "D:\Musikk\Folder"?
