I am using FreeFileSync & RealTimeSync to auto-sync some folders on a USB drive to my PC hard drive. After upgrade to version 10.3 RTS does not get active automatically when I plug-in the USB drive. If I restore the RTS window from the taskbar and press the "Start" button, it gets active immediately. As a workaround, I downgraded FFS & RTS to version 10.2 - it gets activated after USB drive plug-in, as usual.
Specifics of my configuration:
- OS: Windows 8.1
- I use FFS config file (ffs_batch) for RTS
- I use volume name (not drive letter) to specify folders on the USB drive
Best regards and many thanks for the excellent work!
RTS 10.3 not activated on usb drive plug-in
You're using the Variable Drive Letters syntax. I'm able to reproduce the issue, investigating...
Fixed for the next release: https://www.mediafire.com/file/f6qjqahhrqc9smc/FreeFileSync_10.4_%255BBeta%255D_Windows_Setup.exe
Wow,Great, I have the same question,When i install version 10.4,It's solve my quetion,thx very much
I had the same problem, and 10.4 solved it for me too.
OS - Windows 10 (1308).
Brilliant. Thank you.
