RealTimeSync won't recognize USB
Schvenn
I've created the job, using the unique [volume label] variable and successfully tested it.
The parent and destination directories are used strictly for backups and do not have constant activity.
I saved the resulting ffs_batch job to the root folder of the USB drive.
I created and saved the ffs_real job and copied it to the Startup items and while the program runs, the System Tray icon always remains grey, never recognizing that the USB drive has been added and therefore, never starting.
I have to open the icon from the System Tray and click the Start button in order to get RTS to recognize that the [drive name] is available.
Once the batch does run, if I unplug the drive, RTS will appropriately turn grey.
However, plugging the drive back in does not cause RTS to turn red again and it will indicate that it's still waiting for the [drive name] to be available.
Is there something I'm missing here?
