I read lot of topics on portable version but (may be it's me as not native speaker) I miss a point.
From my main PC I need to bring with me some files using portable devices (USB sticks and drives) and even sync some of them on my work PC.
Since one USB stick can't store all what I need I used to store different groups of foder in different USB sticks.
With the donation version am I able to:
1) Use the exe to install locally in the main PC
2) Use the zip to install the portable version on many portable devices?
Many thanks
Clarification on use of portable
Please Zenju,
may I know about above?
Should I go for an old 'ad' variant of FFS?
many thanks
many thanks
Generally you should be good, as long as you keep the number of "many portable devices" rather down, since the Donation Edition is expected to be used by a single user: https://freefilesync.org/faq.php#donation-edition
