I've been having trouble downloading large files larger than 500MB for a while.
It's a FTP server (IIS) with SSL in the data center.
Also an update to version 10.5. and the new FTP timeout function does not help.
Error:
"[19:30:11] Info: The file" *.exe "can not be read.
CURLE_OPERATION_TIMEDOUT: FTP response timeout
125 Data connection already open; Transfer starting. [Curl_easy_perform] "
The files are downloaded once and repeated. This will take about 10 hours to download the open files.
Can you help me?
Thank You!
Trouble downloading large files with FTP
i've got the same problem
What does FreeFileSync show for "bytes/sec"? Currently there shouldn't be any timeout imposed other than what is user-configurable. During FTP transfer if the "bytes/sec" is 0 for the number of seconds that are set as time out, an error such as the above would be shown.
i updated to 10.6 but the error still occurs.
160MB files syncronized. 700MB files are not synced
125 Data connection already open; Transfer starting. [curl_easy_perform]
-> Automatische Wiederholung
[20:13:12] Info: Erstelle Datei "XXXX.exe"
[21:22:56] Fehler: Die Datei "XXXX.exe" kann nicht gelesen werden.
I attached a screenshot from the sync from the big file
How does the screenshot and the log message relate? The log indicates a runtime until failure of over an hour ([20:13:12] - [21:22:56]) while on the screenshot it's only 11 min with 1,3 MB/sec.
the screenshot and the log fit's together.
I have set a repetition and a timeout of 1200sec. so it takes one hour for this single file
Same issue? viewtopic.php?t=6928
