As several people here, I also have problems with the timestamps. File Sync 10.7 doesn't appear to be able to change the modification time. I am not using MTP, but instead a network drive. I might add that File Sync 9.x? used to handle this on the exact same setup without problem. It's a bit frustrating as this way you don't really get a true mirror of the disk.
Update:
It's actually quite similar to this thread viewtopic.php?t=4798, just the other way around. I used File Sync 10.7, 9.x and 8.10. All snyc processes worked fine. The modification date is set to the same day as the original file. Then after a couple of seconds it gets changed to the current time. When I use the windows explorer and manually copy the files, this does not happen.
Modification Time does not stick
Ops, now I really feel bad. I did have a look at the FAQ. I'll have a look. It's definitely the new operating system of my Synology. Used to not do it half a year ago. Thanks for the support.
