Variable Drive Letters
cayenne
would it be possible to add functionality to manage letter problems via GUID windows.
For information, the msdos command "mountvol" allows you to know the GUID.
there is also the msdos command "vol".
If there are translation problems, it is because I speak French and I have used a translator.
Sincerely
Antoine
Did you try the solution provided in theVariable Drive Letters section of the Manual?
markusoft
[volume label of drive]
