It happens when I open it.
s9209122222
Fatal Error: Mismatch between the program and library build versions detected.
The library used 3.0 (wchar_t,compiler with C++ ABI 1002,STL containers,compatible with 2.8),
and your program used 3.0 (wchar_t,compiler with C++ ABI 1009,STL containers,compatible with 2.8).
OS: openSUSE Leap 42.1
What version of FFS are you using?
s9209122222
What version of FFS are you using?Zenju
7.6-2.1
Where did you get that from? Currently there is no FFS 7.6 for OpenSuse:
viewtopic.php?t=671
s9209122222
viewtopic.php?t=671Zenju
https://software.opensuse.org/package/FreeFileSync?search_term=freefilesync
FFS 7.4 works fine for openSUSE.
