Just wanted to know if anyone has used filesync to sync files but to remove the right side file directory structure.
For example. Find all .pdfs on C:\Temp\NewFolder\ and paste the new files in N:\Transfer.
At the moment Filesync copies the NewFolder directory to the N:Transfer\NewFolder.
thanks
Hong
Sync files but not folder structure
Check out Ctrl+T option (Copy files selected on the main dialog to an alternate folder and thereby save a "diff": ) on the Manual page Tips and Tricks.
