Here is the scenario:
the computer is accessed via Remote Desktop Protocol, and FFS is used
FFS is not closed
then the computer is used locally/directly
this causes the child windows (completion graph, warnings) not to appear on screen. They seem to repond to keyboard input, but are not visible.
I see it in 10.9 on Win 10, I think the problem appeared quite recently (10.8? 10.7? I'm not sure). But it is definitely relatively new, as I've been using FFS switching between RDP and direct for years without the problem
possible error: child window not showing after RDP
Looks like it's been fixed in 10.10 - thank you!
Seems to have been the same error: viewtopic.php?t=6156
