On Windows, in a multi-monitor setup, when synchronization encounters an error the dialogbox is presented off-screen. The syncronization screen seems as if it was unclickable since the modal dialogbox is getting the focus.
A workaround:
1. Click on the synchronization window, the hidden dialogbox will get the focus.
2. Press Alt+Space -> Move, to move the dialogbox into view and deal with the error.
PS. FreeFileSync is amazing, the wealth of features and the fact it's basically free is simply stunning! Huge thanks!
off-screen error dialogbox in multi-monitor setup
Does this also happen with the latest FFS 10.10?
I have the same issue, FFS10.10 on mac.
Was doing a big sync job, an error message came up for 1 sec then the window disappeared, I can't click on anything else, as if the error window is on top, but invisible.
I even went and connected another monitor, but the error window is just not there!
Could only quit FFS to fix it...
@Infinum: Can you tests if the problem is solved with the following beta? https://www.mediafire.com/file/gjiwcratvdzs1p3/FreeFileSync_10.11_%5BBeta%5D_Windows_Setup.exe
@Zenju: as much as I tested the beta it worked well. The conditions weren't exactly the same but if I ever come across the error again I'll let you know.
BTW can you add a donation option by means of cryptocurrency either directly or using a payment provider like BitPay/CoinGate etc.?
Can't recommend any particular provider but AFAIK some of them offer an option do immediately withdraw funds in a national currency like USD, so you would not have to exchange it yourself.
I do not use PayPal and avoid using my card on the Internet but still want to support your work, so a payment with crypto would be most convenient.
