Turkish translation
turkish.lng missed in v10.11 . There was no problem with 10.10. What happened, will you add it again ?
Unfortunately there is no dedicated turkish translator currently.
But there was. I guess there was minor changes for 10.11 when it comes to localization. turkish.lng which belong 10.10 version could stay with new version but you prefered to remove it
Did you mean your Turkish translator will not support you anymore? Cause when I use old turkish language file with 10.11 it works. No need to remove it.
I did not get my answer. For anyone who need Turkish language support here is in attachment the last working turkish.lng file from v10.10 .
@fatihbjk90 I'm back as previous Turkish translator, updated the translation for v10.14 and will help to keep updated.
While waiting ZenJu release new version you can use updated file as attached.
