Can only 1 event be selected? (On Success or On Failure or On Completion)
I would prefer to run a command when it Succeeds and one if it Fails... however, the drop down only holds one event.
Please advise.
Chuck
On Success / On Failure
You can evaluate the FFS return codes in your own script.
Thank you
