Feature Request: Sync a single entry from a job
plastilino
Allow the user to sync a single folder from the list, maybe using an entry in the contextual menu
plastilino
Zenju, tanks very much for the links.
I will experiment when at home
plastilino
Zenju, it seems you mentioned a different feature: once the complete comparation is done, sync only the selected files.
I was meaning to compare and syncronize only a single entry (pair of folders) from a job
Create another job for those two folders
plastilino
Create another job for those two folders xCSxXenon, 26 Jun 2019, 17:57
plastilino
Bravo!!
