Hello
I really want to use the new version with multi thread file copy. But the new release does not have XP compatibility.
Can you help?
Thank you
FreeFileSync 10.13 not running on WinXP
Zenju has concluded the Windows XP support in FreeFileSync as of version 10.12. You can go get FreeFileSync 10.11 from the Release Archive page.
does this mean that the 'new' versions of FFS are not compatible with WinXP? or does it only mean that new features won't work on WinXP?
Have you tried installing it? That will probably answer all your questions
