Comleted with errors - No files backup stored in 3 drives backup
terick
Hello
I was create backup and ran the freefilesync before and it has work successfully. Now I have created a NAS machine and run again this freefilesync and display the error like this:
Completed with erros
- Cannot set directory locks for the following folders "Z:\Desktop
- Cannot write file "Z:\Desktop\sync.ffs.lock",
- Erro Code 5: Access is denied. [CreateFile] "Z:\Document
- Cannot write file "Z:\Document\sync.ffs.lock", and so on
- Cannot copy file
- "C:\Users\User\download ……
- Erro Code 5: Access is denied. [CopyFileEx]
Can anyone give why this error happens like as given above please?
Thank you in advance
Typically that is caused by the permission settings on the NAS. Can you manually copy files to/from the server using just explorer?
terick
Typically that is caused by the permission settings on the NAS. Can you manually copy files to/from the server using just explorer? xCSxXenon, 10 Aug 2019, 16:08
Actually, permission has been set. I can create many folders and any files e.g. excel, word, etc. Copying files from anywhere and paste on NAS it's really work.
I was created the partition localy thru the C: drive, and run this program and it was works. The problem I have faced now, I'm trying to re-run and overwrite the batch I saved to the different drive that has been created on the NAS and gave me the errors as I mentioned in my last discussion.
Hope to hear from you.
Best regard
