I use FFS for more than just backup/sync
I need a way to RENAME the current LEFT side / RIGHT side files
right click on file list - RENAME
Rename window
Insert XXXX at Position [XX] or
Append XXXX or
Remove XXXX at Position [XX] or
Delete XXXX or
or if there is better way, I need to keep ALL VERSIONS of a FILE that DIFFER in a COMPARE
REQUEST: ability to RENAME
The program is specifically created for backup/sync. It does not support more features than it is designed to do. What you want is completely separate from the function of FFS. You can right-click > show in explorer > then rename from there.
Actually, a simple rename function would be nice to have. With the ability to select and rename a group of files, and to preserve the common part of all names. It's a "to do", but not the highest priority.
"Rename (F2)" has been added! Download beta version
You can even select multiple files at once: FreeFileSync will detect patterns and highlight the file name similarities: https://freefilesync.org/manual.php?topic=tips-and-tricks#multi-rename
