I'm trying put together a kind of incremental backup that works as follow: whenever I add an file to a particular folder/subfolders (located on my external HD), I'd like to automatically copy that newly save file from my folder/subfolders (located on my external HD) to my backup HD (located on another external HD), that would mirror the same folder/subfolder structure.
In other words, when I move an new file to my primary storage folders/subfolders, I'd like to copy that new file to be automatically backed up on my back up HD (which will have the same, corresponding folders/subfolders and files). I should add that I have old files in my back up HD, within the folder I'd like the backup folder/files to go -- and so I don't want to disrupt or delete them!
Is FreeFileSync an appropriate app for this function? If so, what are the suggested steps to do this?
Thank you...
Folder action, mirror back up
Just define the sync in FreeFileSync (FFS) and store as a batch-file,
and use RealTimeSync (RTS) to trigger FFS to run the batch-file.
Ok, thanks.
But would the Sync variant be Mirror or Update (or even Custom) base on what I described?
Thanks again...
Thanks again...
Also, as far as storing it as a batch-file, and use RealTimeSync (RTS) to trigger FFS to run the batch-file...
I assume that means selecting "Saving as batch job..." Correct?
And then checking the box for "Run Minimization," right? If so, what other selections should I make (or preferences in this set up that I should toggle)?
If not, please advise... Thank you!
I don't think you need a Custom variant; either Mirror or Update will do.Ok, thanks.
Thanks again...jprint
If you want files deleted from your left/source location also to be deleted from your right/target location choose Mirror; if you want files deleted from your left/source location to remain in your right/target location choose Update.
Follow the instructions in the manual ( https://freefilesync.org/manual.php?topic=schedule-a-batch-job ) "Schedule a Batch Job" item 1 through 5.Also, as far as storing it as a batch-file, and use RealTimeSync (RTS) to trigger FFS to run the batch-file...
If not, please advise... Thank you!jprint
Regarding RealTimeSync, the manual-page ( https://freefilesync.org/manual.php?topic=realtimesync ) should tell it all ...
Thanks! So, I want files deleted from my left/source location also to be deleted from my right/target location - BUT, as I said, I have old files in my back up HD, within the folder I'd like the backup folder/files to go (i.e., the right/target location) -- and so I don't want to disrupt or delete them. Would Mirror still work? Thank you agian..I don't think you need a Custom variant; either Mirror or Update will do.
If you want files deleted from your left/source location also to be deleted from your right/target location choose Mirror; if you want files deleted from your left/source location to remain in your right/target location choose Update.plerry
