During a synchronization, files that need to be deleted are placed in the trash. Would it be possible to have an option for permanent deletion rather than trash?
This is necessary when the target directory is in a file system that does not have an associated trash (for example, in the case of a Linux virtual machine that shares a directory with its Windows host). Thank you.
[Feature request] Permanent delete for old files
It is already possible to set things up for permanent deletion of files. See the Synchronisation Settings: https://freefilesync.org/manual.php?topic=synchronization-settings
Thanks !
