Drive Level Synch
Highlander
When I do a drive sync (sync all of the data on drive D to Drive E), the new drive containing the copied data does not Match.
I do a Right Click in windows explorer to get the number of files and directories from the Original and compare that to the new and they do NOT Match, I do another Sync and it shows nothing does not match.
The Original drive has 448,948 files and 35,437 Folders but the Sync Drive has
447,923 Files and 35,420 Folders
Currently using version 10.6
Please assist
Highlander
Also please not I Upgraded to release 10.17 and have the same issue , and I am running the tool using Admin Rights, I tried with and without Admin rights and it makes no difference
