customised file copying files
medindexer
One can save files for selected folder syncing. Where are they stored and can they be copied to another PC so that FreeFileSync on another PC can use the same customised syncs. They take time to prepare otherwise
You can determine yourself where *.ffs_gui or *.ffs_batch files are stored by using the "Save as" button.
You can copy those files to another PC and run the sync there, provided the sync locations involved exist on the other PC or are accessable from the other PC.
You may even use Macro's to make the FFS sync automatically adapt itself to certain settings of the other PC(s).
medindexer
Thank you Perry
medindexer
Sorry, Plerry
