I’m new on Freefilesync, but cantou help if it’s possible to run from terminal, something like that :
“/Applications/Freefilesync.app myBatch.ffs_batch”.
The idea is to put the command on Crontab.
I saw your tutorial, where you suggest to use ICal, but for me is not practicable.
Thank you
Mac Terminal
Doesn't the Manual section on Command-line answer your question?
