I'd love to see a way to ignore or hide error messages or the yellow exclamation next to completed jobs (Mainly the Recycle bin is not supported on network drives). Perhaps there's a way to turn that off and I haven't discovered it yet?
I switched to Free File Sync from the PAID version of Allway Sync and I couldn't be happier, FFS is MUCH better in every way. Keep up the great work!
Loking for a way to ignore or hide error messages or the yellow exclamation next to completed jobs
You can select the Deletion Method in the Synchronization Settings.
Such a simple solution and quick response, imagine that a great program with great support. I'm using the donation version and love it, I'm IMPRESSED. Thanks so much!
