got a quick question
in my power options i have my hard drives set to sleep after 30 mins of inactivity
what will happen when my batch file runs from task scheduler? will it error out and say the HD isnt connected?
there will be a delay from then the task is set to run to when the HD can boot up.
Task scheduler when HDD sleeping
is there a way i can make sure the HDD is woken up before it opens the batch file, or a 10 second delay
or does it already work fine?
Currently hard-coded to 20 sec, but will be made configurable, solving viewtopic.php?t=6702
ah ok, any ETA?Currently hard-coded to 20 sec, but will be made configurable, solving viewtopic.php?t=6702 Zenju, 10 Dec 2019, 13:54
where does it say its 20 seconds delay atm?
He's a dev, he says it's 20 seconds haha
that is trueHe's a dev, he says it's 20 seconds haha xCSxXenon, 11 Dec 2019, 23:15
