I am trying to figure out if the naming convention for versioned files can be changed from YYYY-MM-DD hhmmss into another order.
Alternatively, is it possible to put the timestamps in a different position, for example at the beginning of the file name?
Thanks!
Versioning of name conventions
You may use Macros in your Versioning path definitions (3).
