Drives differ in size after sync
nahydro
Greetings:
New user here.
I have two 6T drives used as backup. Drive B is a mirror of Drive A, for redundancy.
After selecting and copying all files from Drive A to Drive B, the two drives differ in size by approx. 8 gig. I've repeated the operation several times, with the same results.
I installed FFS to do a comparison of the two drives and, if I am operating it properly, it finds only a single 400 byte .ini file that is not shared between the dirves. I am already aware of this single difference.
What could explain the difference between the two drive's volumes?
Thanks.
nahydro
Continued....(sorry, I couldn't find an option to edit my first post)
Also, I tried to set up my compare between A:/ and B:/, to compare the entire drives, however the compare process seemed to complete instantaneously. Would FFS compare all sub-directories under the root?
Thanks again.
