Silent install?
djms1.618
The only reason I'd like a silent install option is so that the project can be supported by patchmypc.com
Does anyone else use this app to patch up their apps? It will only support apps that are free, or freemium, or FOSS, and have silent installers. FFS is unsupported since it doesn't have a silent install switch.
(Only) the FFS donation version supports silent installs. See here.
jaap.verhage
Since a couple of months, I use PatchMyPC and am very satisfied with it. It means a lot less of rather tedious work. It doesn't update FreeFileSync, because it apparently doesn't know that the donation edition of FFS, which I have, supports silent install. Would it be possible to give the people at PatchMyPC a way to differentiate between donation and non-donation versions of FFS, or to support the silent install option in the non-donation version as well? I would greatly appreciate either.
Regards, Jaap, otherwise very satisfied user of FFS.
jaap.verhage
I would appreciate a reaction to my post of 16 May. Zenju?
