first time i install "freefilesync" i can sync with a folder on my NAS, but since a few days it doesn't work.
I use "FreeFileSync 10.19" with "Linux Mint 19.3 Cinnamon 64-Bit".
My local folder is:
/media/heiko/daten/Dokumente
and the folder on the NAS is:
smb://192.168.0.111/heiko/Backups/Dokumente_BAK/dokumente
But if i copy the NAS-folder path in "FreeFileSync" it create
/home/heiko/smb://192.168.0.111/heiko/Backups/Dokumente_BAK/dokumente
from it and this folder doesn't exist.
If i will select the NAS-folder with button "Auswählen", my NAS will not show and my Bookmarks will not show too.
How can i sync to my NAS-folder?
Greetings from germany
Heiko
[solved] Can't sync with NAS-Folder
The problems are the versions 10.18 & 10.19.
With 10.17 it work normally
Now i use the 10.17 with out problems.
Heiko
Heiko
Looks like the same issue: viewtopic.php?t=6871
With the version 10.20 beta it works like 10.17 .OS: Linux Mint Cinnamon 19.3 64-Bit.
Greetings from Germany
Heiko
Heiko
