File Size Limit or time out option?
geestar
I have two donation versions of FreeFileSync and they work perfectly syncing hundreds of files through FTP. The issue I have run into is that it errors out with files over 2 gig. I can see the temp file in the target folder and as soon as it hits 2 gig, it generates error and deletes the temp file.
The storage has 19 TB left and I can use other software to copy large files. I am wondering if there is a limit to the file size or possibly time out switch that I have not been able to find. The connection is 300 fiber and I have tried it numerous times.
Thank you;
Cannot write file "ftp://path/backup_2020_01_09_230002_1585820~79ad.ffs_tmp".
CURLE_OPERATION_TIMEDOUT: FTP response timeout
150 Opening BINARY mode data connection for
geestar
Quick Update.
My storage is QNAP and I was using their FTP Server. I switched the FTP Server to FileZilla and no longer receive the time out error. The issue was the FTP on QNAP. Tried to find the time out setting, couldn't find one.
