I am running a mirror operation from a Server 2008 R2 box to a remote share. The transfer speed in FS is no more than about 20-30 Kbps. If i try doing a regular windows file transfer on this same server to the same destination, i am getting upwards of 20 Mbps. So the issue seems to be on FileSync app. Any ideas as to why it would be doing this?
Thanks for the help!
Slow transfer speed
Check out if Copy files selected on the main dialog to an alternate folder and thereby save a "diff" does the trick for you.
