Revert to text log files!
I just installed the latest 10.20 update and found out that the log files have inexplicably been converted to HTML format.
This is an absolutely baffling change. HTML is horribly inefficient to store data nor is it even meant for that purpose in the first place!
Please revert to text logs or if you must have structured data then XML which is at least fit for purpose and separates data and presentation.
What is the problem with html? How are you using the log files?
I agree with florentine. These are log files. parsing HTML is difficult compared to plain text, XML, JSON, etc. Also the logs take up more space.
I manage a number of systems that generate different logs from various software. Initially I used to email the log files to myself and manually check them. This got too much, so I wrote a PowerShell script to do it for me and emails me a summary. The summary checks the number of logs is correct, and if found, pulls out errors and includes them. I would need to put in a lot of work to update it for HTML logs.
Maybe you could give the option for either plain text or HTML.
Agree on having an option for user to choose which type of log FreeFileSync is generating.I agree with florentine. These are log files. parsing HTML is difficult compared to plain text, XML, JSON, etc. Also the logs take up more space.
Maybe you could give the option for either plain text or HTML. mrvboring, 16 Feb 2020, 11:21
I agree with florentine. HTML is nice but it makes life difficult with sudden unexpected changes like this. The same situation happened the last time log file changes were made. Luckily we test it before putting it into production !
Hi all,
I agree with your requirement, too. I'm using FreeFileSync with an VBS script that is parsing the log file for error events. Since the log files are in HTML format, this isn't possible anymore. HTML is nice to view but not for automated processes. What about giving the user the choice which log format they want by adding a format selector option?
Thank you
TheExpert
Thank you
TheExpert
I also prefer "text" log files. I parse the log files every night for errors. Please make it an option.
I agree with making the html log file optional, because I use a vbs script to parse the log file.
Yes please : make it optional (eventually in de advanced settings) ...
I was planning on post-processing too .... and a 5.5MB html (19.000 files sync) took forever
to load in my browser (OK, I don't have the most modern computer anymore ..... :-)
Kind regards
Guy
Kind regards
Guy
I would like to get back txt format of log too.
Thank you very much.
By the way.
It will be nice to set limit of log files for each sync job separately. If you work on PC about 8 hour per day and have job that sync each hour and set limit to 30 days, it's 240 log, but if you have concurently another job runnig by RealTimeSync, it make 10000+ logs!
By the way.
I also just noticed that the icon images are being hotlinked directly from the FFS website. It's not even saving a local copy with the installation! This is a complete waste of bandwidth for FFS AND creates privacy implications since every time anybody opens the log in a browser it will ping the FFS servers.
I'm in favor of html as a global option. The new format looks nice but I'm doing simple checks with files and dont want a browser to check a text output. Great program.
I agree with the others. Parsing html ist complicated.
I check the logfile filtering errors, making a small result-log and so on.
Sending html Logfiles per mail can be blocked from some mail-programs ...
With Windows cmd-tools you cannot easy handle UTF-8 files,
it must first convert in ANSI for "findstr" an so on.
Therefor in Windows you need thirdparty programs, lile gnu-tools for Windows.
Also to convert "html to text" there are some thirdparty tools like:
https://www.nirsoft.net/utils/htmlastext.html.
It's much better Logfiles are txt files!
Please revert to .txt/.log or making an user-option in globalsettings.
Yes, please make this log file in HTML as an option. And leave log file in plane text!
Need plain text log files back ASAP! Have to switch back to .19 for now.
A new global option to select between HTML and plain text has been added for FFS 10.21
Thank you!!!!A new global option to select between HTML and plain text has been added for FFS 10.21 Zenju, 17 Mar 2020, 18:43
@Zenju: Thank you for bringing back the plain text log files.
In the global settings file you can add the format option to this XML tag:
<LogFiles MaxAge="30"/> --> <LogFiles MaxAge="30" Format="Text"/>
It looks like the plain text log files are different from the ones of FFS 10.19 and earlier. In Windows (Server 2012 R2) notepad they aren't shown with line feeds any more. The line feed is only visible by opening the files with Notepad++ or similar editiors.
Hopefully the parsing of these files will work with Visual Basic Script as it was with the ones of FFS 10.19 and earlier.
Looks like the new logs are using LF for EOL. The previous logs (on Windows at least) used CRLF.It looks like the plain text log files are different from the ones of FFS 10.19 and earlier. In Windows notepad they aren't shown with line feeds any more. The line feed is only visible by opening the files with Notepad++ or similar editiors.
Hopefully the parsing of these files will work with Visual Basic Script as it was with the ones of FFS 10.19 and earlier. TheExpert, 18 Mar 2020, 18:09
I'm using programs written in VB6 and and they ARE NOT reading the log file correctly. Looks like each line needs a CRLF not just a LF. I've reverted back to 10.19.
For me parsing the plain text log files from FFS 10.21 with VB scripts is working again but the parsed lines are listed twice.
Hm, does it make sense to add CR+LF back for Windows?
I was under the assumption that CR could be considered legacy. It certainly is not used on Linux, deprecated on Mac since OS X, and not needed by (all?) modern text-processing apps (including the tools that ship with Windows).
Are there major usecases that need CR on Windows?
The default editor of Windows Server 2012 R2 (Notepad.exe) doesn't show the plain text log files correctly if there's no CR. And it looks like VBS is also awaiting a CR for identifying the EOL.
With the default editor of Windows 10 the plain text log files are shown as expected with line feeds.
Thanks for adding this back!!!
Why are the errors logged twice in the plain text log files? It's nice that there's a short list of the error messages when opening and reading the log file manually but when the files are parsed the errors are parsed twice. At the moment I have no idea how to prevent the second parsing.
@TheExpert
I saw you were using a VB script to parse log files. I began to write a parser in Python, but I'm really short of time! Could you, please, send me your VB script?
I'd be very grateful!
Thanks.
Thanks.
@Malbec@TheExpert
Thanks. Malbec, 28 May 2020, 17:32
here you can get the VB script I'm using and maintaining: viewtopic.php?f=2&t=2095&p=18563#p18563.
@TheExpert
Thanks a lot!
Thanks a lot!
Personally, I kinda like parsing HTML sometimes. Of course, I don't parse form HTML-->TXT files, I parse from HTML-->SQLServer.
If you guys ever need to parse HTML, I *HIGHLY* recommend this function.. But DON'T read the licensing terms, because then you won't use it! Just PRETEND it's open source!
(I'm not a lawyer, please dont' follow my joking recommendation)
https://sourceforge.net/projects/sqldom/
