Been trying different ways to configure FFS filters with out succes. Running FFS as administrator. When I open the map through FFS I can“t see the catalog files *.lrcat. Next try is to rename the catalog with shorter name... any other ideeas?
Regarrds Peter
Unable to backup (even see) Lightroom classic catalog
screen dump. The same folder viewed through FFS and windows explorer
?? No ideas? Someone?
It is not clear what you are trying to do.
The FFS dialog window shows only folders, as stated in the caption "Select Folder", because its purpose is to select a folder.
What action opens that window?
Exclude (or Include) Items via Filter
https://freefilesync.org/faq.php#task-scheduler-networkMapped network drives are tied to a specific user session and other user accounts do not have access.
Now if you have enabled "Run with highest privileges" in Task Scheduler, a new user session with elevated rights will be created. This session corresponds to the same user account, but it will not have access to the non-persistent drive mapping, because it's a different session after all.
