Good Morning.
I have a folder with multiple subfolders. I want to synchronize the files only to another folder. Can this be done?
Greetings.
Synchronize folder with subfolders, but only files.
Look into using Ctrl-T.
Thanks for your comment.Look into using Ctrl-T. Plerry, 02 Mar 2020, 08:02
I do not understand what you mean.
You can detail me more.
I need two folders that synchronize with each other and the changes are updated.
The first folder contains folders and subfolders with files.
The second contains all the files but without folders.
Greetings.
