Good Day,
We have a high-security environment and need to control the smtp relay settings for the mail notifications. Can this be done?
Custom SMTP settings for email noticiation
+1 for this feature! Whether it be in the homelab or at work, I use my own mail relays exposed only to the LAN with docker. They then centralize communications to a public provider like Microsoft365 or OVH with 2FA and encryption.Good Day,
We have a high-security environment and need to control the smtp relay settings for the mail notifications. Can this be done? coritokael, 25 Mar 2020, 14:11
Do you think it will be possible in the future to set our own email parameters?
I take the opportunity to thank all the team behind this great software. Happy to support such project!
Best regards.
I've added it as a TODO.
👍🏾I've added it as a TODO. Zenju, 10 Jul 2024, 07:45
I registered just to say that this would be greatly appreciated :)
Hi All, I support this idea! SMTP setup is reason why I register here as well :) Let's do it!
Here is some information that's together regarding the use of your own SMTP server. You can't remove the built-in server but you can add your own.
https://pzgg1fpeau.joplinusercontent.com/shares/MwVqXigOtRQG8PiM99MKvc
