I got few special files in my NAS that I want to save them encrypted on my cloud. Therefore, I install cryptomator and associate a drive pointing to my cloud.
The idea is to work as usual on my NAS. FreeFileSync synchronize NAS folder special files with cryptomator drive and OneDrive performs automatically cloud synchronization.
I set FreeFileSync (ver 10.22) accordingly.
First I ran it manually and I got the problem regarding "Delete.x.sync.ffs_lock". Thanks to this forum that gives me the solution. I update the Dokan library to 1.3.1.1000 and all is OK. So now I run successfully my FreeFileSync miror definition and OneDrive gets up to date.
However, when I try to run it as a batch using task scheduler I got an error saying that target drive (cryptomator) is not found.
Here messages log:
19:00:02 Erreur: Impossible de trouver les dossiers suivants :
O:\
Impossible de lire les attributs du fichier "O:\".
ERROR_PATH_NOT_FOUND: Le chemin d’accès spécifié est introuvable. [GetFileAttributes]
19:00:02 Erreur: Impossible de lire les attributs du fichier "O:\".
Drive is accessible from explorer but it does not appear in diskmgmt.msc
Any idea and/or help will be appreciated. Myself I am a bit stuck. Thanks
Batch fails while copying in cryptomator drive
Many Thanks.
I read your post and corresponding information attached to your link. However, current status has changed. In fact virtual drive created by Cryptomator does exist and I can see it under Windows Explorer. But when I open FreeFileSync and when I try to define target folder I cannot see it anymore (It used to be). Look's like the Cryptomator virtual drive folder (Cryptomator file system) is invisible for FreeFileSync.
After more investigations, problem is on FreeFileSync that is not able to detect correctly Cryptomator virtual disk. I try another sync utility that is working fine.
