In FreeFileSync, apparantly I always need to click 'Compare', and then I can click 'Synchronize' to do the actual synching.
If I only click 'Synchronize', FFS does not do a Compare first.
Is there a way without having to click the 'Compare' button first?
In other words, is there a way to do a 'Compare' and then a 'Synchronize' with one button click?
( I am lazy ... ;-) )
Kind regards
FreeFileSync - Compare and Synchronize, possible in one click?
When I just click on 'Synchronize', it says that there are no files to copy. Even after I deliberately have added a new file to the source folder.
When I do a Compare, it sees the newly added file.... Just doing Synchronize directly (without doing a compare first) does not see the new file .....
There is something weird going on.
- I add a new file to the source folder.
- I click 'Synchronize'... No files are copied to Target Folder.
- I Exit FFS.
- I restart FFS.
- I click 'Synchronize'. Now the file is copied from Source to Target ....
It seems that just clicking Synchronize does not do a Compare. Unless when FFS has just been launched ....
- I Exit FFS.
- I restart FFS.
Yes, FFS only runs a comparison if you haven't done so already manually.
FFS batch jobs that run on double-click is probably a better fit for your requirements. (They can be attached to the FFS icon in the Windows task bar, which makes them more easily available for manual exec.)
Ok, thanks for your help.
Can I put this somewhere as a feature request?
- Add a checkbox in the 'Synchronization' settings: "Always run a Compare before Synchronizing"
Yes, I created a batch file. Double-clicking the batch file compares and synchronizes in one run.FFS batch jobs that run on double-click is probably a better fit for your requirements. (They can be attached to the FFS icon in the Windows task bar, which makes them more easily available for manual exec.) Zenju, 30 Mar 2020, 13:48
Thanks.
I still would keep my feature request though .... ;-)
I also vote for this function:
"- Add a checkbox in the 'Synchronisation' settings: "Always run a Compare before Synchronizing"."
I initially had the same problems as RayJohnson and was confused by this. I was about to switch to another software.
This small additional function should really not be a problem for the programmers to implement.
I think it is inelegant to create everything by batch for such a frequently used standard process.
I can actually see the benefit of adding such a button/feature. I know the batch configs can do this, but it would be nice to have a way to do this in the GUI
What's wrong with viewtopic.php?t=7132&p=29615#p23742 ?
Because it simply complicates things senselessly for beginners. As a beginner, I did not assume that the software would automatically compare only once. Creating a batch file to be able to use such a simple standard function (compare more than once automatically) is strange and unintuitive. I am also speaking here as a person with experience in product marketing. As I said, I almost changed software for this reason.
So here's the issue:
If you run a compare on it's own, then make changes to one of the locations, then click synchronize, the changes made between the compare and sync are treated as if they never existed. Since the compare ran before the changes, whatever is queued up won't include the changes. Sure, it would be easy to click compare again after making changes, but it would be a nice little addition to have a "compare & sync" button in the gui. Maybe a right-click on the config and a 'run' entry in the menu that pops up.
It definitely won't affect me, since I make all my changes before ever opening FFS anyway, or I just know to re-compare after changes are made.
I don't quite see the scenario where such a function would be useful. Why would someone want to sync again after he just did before? If on the other hand the time span between syncs is large, why is FreeFileSync left open?
Also: An automatic "compare" before sync means that all manual changes to the file list will be lost.
If manual changes of the file list are not important, then why run a GUI sync at all. A ffs_batch job is tailored exactly for this scenario.
Well, I use FFS like this: I usually have FFS (GUI) open most of the day. I currently have 23 different projects (.ffs_gui) defined in FFS. I use FFS to backup to a network drive over VPN.
During the day, I work on 2 to 5 different projects (of the 23). Whenever I switch projects (or when I go for a cup of coffee) I make a backup (clicking 'Compare', then 'Synchronize'). This can be upto around 10-12 times per day. Having to click only 'Synchronize' instead of 'Compare' and 'Synchronize' would save me time...
I would welcome a one-click Compare-and-Synchronize function... Furthermore, I can not think of any argument against it ...
The only issue is a small one, and I wrote it step-for-step in my previous response:
The ability to one-click run a sync from within the GUI is only applicable to this one very niche 'issue'If you run a compare on it's own, then make changes to one of the locations, then click synchronize, the changes made between the compare and sync are treated as if they never existed.
And the benefit is 1 click instead of 2 ....The only issue is a small one, and I wrote it step-for-step in my previous response:..... xCSxXenon, 11 May 2021, 04:55
Correct ^
Super small issue, definitely a quality-of-life enhancement
Which, by the looks of things, after four years has still not been implemented.Correct ^
Super small issue, definitely a quality-of-life enhancement xCSxXenon, 11 May 2021, 14:42
The reason your users are asking for this feature is that you should be able to execute a one-button sync from the GUI without having to jump through hoops. Most other leading file sync programs work by simply hitting sync, and they automatically compare first. Not having to manually hit compare first, then sync separately. That is why so many assume FFS is defective when they first try it and quickly bail to search for a more user-friendly alternative. Not everyone needs or wants to create batch jobs to enjoy what should be a standard feature for this class of program.I don't quite see the scenario where such a function would be useful. Why would someone want to sync again after he just did before? If on the other hand the time span between syncs is large, why is FreeFileSync left open?
If manual changes of the file list are not important, then why run a GUI sync at all. A ffs_batch job is tailored exactly for this scenario. Zenju, 09 May 2021, 19:03
