WinMerge exit code 1
Ulfius
Ever since 10.23, I receive this error when trying to use WinMerge.
Exit code 1: 'WinMergeU.exe' is not recognized as an internal or external command,
operable program or batch file. [WinMergeU.exe "%local_path%" "%local_path2%"]
WinMerge works from the command line and it works if I go back to 10.22. Trying the "& exit 0" workaround stops the error but doesn't start WinMerge.
Gianni1962
Try adding the full path to where WinMergeU.exe is located.
If you are using the 32 bit version on a 64 bit system:
"C:\Program Files (x86)\WinMerge\WinMergeU.exe"
Otherwise:
"C:\Program Files\WinMerge\WinMergeU.exe"
Ulfius
The full path works, but something changed in 10.23 that caused it to stop working without the full path.
Gianni1962
You are right, take a look at this discussion:
Run a command on completion
